BIOS-Update
gmb65
Besucher
BIOS-Update
My Bios-Version is R0208D1 Phoenix-Bios
I have a Vaio SR21K :smileygrin:
Is there a newer Bios in the ftp-section?
What ist the name of the update?
I need the Bios-Update, because my Bios does not recognise my USB-Stick for the boot-sequence, so that I cannot boot from USB-Stick or, I guess, also from other USB-devices like CD, DVD... :angry:
tia
georg
2 ANTWORTEN 2
kee-lo_
Mitglied
The only way to know is checking VAIO-Link.
If there isn't then there isn't.
Do not try flashing the BIOS with anything else but Sony aproved BIOSes.
profile.country.BE.title
aranloko
Neues Mitglied
Only BIOS upgrade available on vaio-link is the one required if you upgrade to Win XP, if you are still running the original W2K OS you better stick to your current BIOS
