Can anyone help with making this connection work?
JBGLondon
Hi there,
just grab a belkin usb adaptor from www.amazon.co.uk and you should be up and running.
Once your usb adaptor comes, follow the installation process and then also you have to download the latest Nokia PC suite from the Nokia website.
I've done it myself with my new N70 and it works fine.
greetings,
Dionisis
