after my last windows update, windows would not boot. after the vaio logo screen in dos mode it would request the bios master password.. when entered it would go directly to recovery process..even after recovering it continues to do the same.
however if I press F12 during the boot process it bypasses the password screen and starts to boot windows as normal.
how can i recitify this. I am unable to go into the cmos settings. I think a bios update might be needed.
I have a VGN A317m had for over 18months and have not changed any hardware.
any help would be greatly appreciated
thanks
Press F2 on bootup and go to bios password, and set it to no password
If nothing else works, you could try finding the BIOS CMOS on your motherboard. Somewhere close to that there should be a jumper to clear the CMOS. Just switch the jumper for about 10 seconds and put it back. If there's no feature to reset the CMOS, you can also look for the little battery that powers the CMOS, and remove that for a few minutes.
That should put all the BIOS settings back to default.
In case you knew this, sorry for assuming you didn't.
pressing F2 does not get me into the cmos settings. It reports an error and then requests the cmos password ( which I thankfully know) after entering it the system directly goes into recovery setup.
pressing F2 or escape dont work. pressing F or F8 or F12 does somehow bypass the password and load normally into windows.
I'm not to keen to play with the hardware to reset. is there any other way of doing it
thanks
Hi abuyahya,
I think it may me worth contacting Vaio-link for there advice...:smileyconfused:
Uh oh, sounds like the BIOS is a little screwed
thanks for advise will try vaio link
not having any luck!
anyone else had this problem.
the beep code in the AMI bios gives a recurent beep. only stops when i press a key. i can't find anything on this!
HELP Please!
Hi abuyahya,
Did you get any help or a solution form Vaio-Link Sony support...
