What is a bootdisk for and wich is the best program, because I got a crash, had to use vaio recovery disc, C disc totally lost, had a back up but was a true copy so that won't work putting it back because it won't activate, so had to set up each programm etc etc, so please help if it will happen again, thanks
What´s happen with your computer... ???
Just one software can assure that this doesn't happen again...
Symantec¿s Norton SystemWorks¿ 2005 Premier
gives you powerful tools to solve PC problems and protect data. This easy-to-use suite helps you eliminate viruses, back up your files, and prevent computer problems. A new recovery disk allows you to recover data even when Windows® won¿t start up.
More information at the link :
http://www.symantec.com/region/reg_eu/product/nswp_index.html
