Built in motion eye in fe41z
Refat
I have installed the latest update with my motion eye, and sometimes it works all fine and sometimes it tells me there is no input and also tells me that maybe I am using in anothe rapplication, however I am not.
I need some1 to help me if they can and I appreciate it very much, and so I need steps easy like 1 2 3 etc........
rich912
Hi Refat,
This is a know issue and Sony are working on a fix…
Go n-éirí an bóthar leat
lisa.cleverley
I have the very same computer and had the very same issue. I've managed to fix it with the help of another thread on here and whatever I did.
Take a look http://club.vaio.sony.co.uk/clubvaio/gb/en/forum/viewthread?thread=41128http://club.vaio.sony.co.uk/clubvaio/gb/en/forum/viewthread?thread=41128
Hope it works for you and good luck.
Lisa
