Buy a FE41S
Rich77
Buy a FE41S
Hi
I am just wodering if the FE41S has a SD card slot??
thanks
8 REPLIES 8
Thalamus.
Champion
Hi
thanks
Hi Rich77,
According to the specs the FE41S does not have a Secure Digital (SD) card slot.. :slight_frown:
MattWilson
Actually Sony supply a PC express card that will take SD cards so as long as you have that pluged its find. Just so you know it is internal as it slots in the side.
FE series are very good. :slight_smile:
kee-lo_
Just buy a cheap 17-in-1 card reader - shouldn't be more than £5
MattWilson
The PC express card comes free though. Theres no need to spend any money at all. :slight_smile:
kee-lo_
That comes with the FE? The others don't have that
MattWilson
Well i got one with my FE series Notebook and my girlfiend got one with her C series notebook so i am guessing its just something they supply with it. :slight_smile:
andrewparkes
yes i got one with mine, little silver card adapter, it takes SD, XD and MMC. Model number is VGP-MCA20.
Just came across this though, you may find it useful
http://forum.notebookreview.com/showthread.php?t=92049
MattWilson
I am sure there is a driver update to allow it to use all the modern cards. I mean Sony released an update for the internal MStick slots in the older notebooks to they could support the 8GB cards - Here
