Call me thick but how on the AR31S do you....
wuzzbert
... alter the screen colour and and other screen setting apart from the blue FN buttons.
and does anyone know of any good guides on connecting it up to a sony LCD tv. I tried it and it does all sorts of wierd things!!! Can i not have it so the screen on my tv looks exactly like the scrren on my laptop, ie the mouse moves to the same points even though they are different sizes and resolutions. Ive tried using the laptop on my tv with the laptop screen down but it still doesnt fit the screen in correctly. I really need some help here!!!
rich912
Hi wuzzbert,
Right click an open space on the desktop and select 'Personalize'.
Go n-éirí an bóthar leat
davemee
Windows will let you 'mirror' (ie, duplicate) the same display on multiple monitors AT THE SAME RESOLUTION, or will allow you a second monitor with a different or identical resolution.
I get some semi-random behaviours when I close lids and connect monitors, but to save being told to run system restore again, i don't bother telling sony tech support about this problem.
