Can I change my laptop's ram??
lohohel
I have a VAIO Vpceb1s1e with 4GB DDR3 1333mhz 1.35v ram and I have found on a lot of shops an upgrade kit with 2x4GB DDR3 1333mhz RAM but it's not 1.35V, it's 1.5V.
Will upgrading my ram from 1.35V to 1.5V harm my laptop??
rich912
Hi lohohel,
Crucial supply 1.35V for your model. Possibly the others you have looked at are 1.35/1.5 dual-voltage modules.
http://www.crucial.com/uk/upgrade/Sony-memory/VAIO+VPCE+Series/VAIO+VPCEB1S1E-upgrades.html
Rich
Go n-éirí an bóthar leat
