can i get 5.1 through optical out in VGN A417S's docking station? please help
giodeflo9
i really hope someone can help me because i'm going crazy with this tonight
i've just bought a optical cable and i connected my Vaio VGNA417S docking station's optical out to my sony's DAV-S500 Home cinema's optical but when i play dvds or even Pink Floyd's Dark Side Of The Moon for SACD 5.1 the sound only comes from 2 channels in the home cinema and if i try to change the sound fielnd in the home cinema, the home cinema display says 2 channels 96kHz.....is there any setting i need to change in the laptop or maybe the laptop sound card simply doesn't support 5.1?
Is there any solution for this please
Thanks in advance for your time
Gio
rich912
I am afraid that is your problem. You will need an external 5.1 USB or PCMCIA sound card:smileysad:
Go n-éirí an bóthar leat
giodeflo9
hello mate,
thanks a lot for your reply
i have checked online and it looks like i can only buy an external USB SoundWave Optical 5.1 product from US shops (i live in the UK) and shipping is very expensive
Thanks for your time
Gio
rich912
They are available in the UK, have a look here, but also try a further Google with UK in the search field.
