Can I use a VGA-TV adaptor (just cable) with VGN S4?
franito
Hello,
I have a VGN-S4M/S with the GeForce Go 6200 w/Turbo Cache and it has only the vga-out connector. I have seen there are several adaptors that convert the vga into rca. For example:
http://i2.ebayimg.com/02/i/000/81/94/48fb_1.JPG
(sorry to use this as an example :S)
They do not convert the signal, just the cable. They say they need a TV signal produced by
the vga-out connector but I do not know if my Vaio will produce this so that I can use
that adaptor
Does anyone know??
Hi franito and welcome to Club Vaio.
I'm afraid this will not work with your Vaio. This needs the VGA socket to output a 'TV Out' signal and I don't know any PCs that do that.
Your VGA socket outputs a RGB signal with synchronisation for use with a monitor and unless you have a TV with this input (some modern panels do), you are going to need a converter box.
You can get a VGA to TV converter - quite expensive @ about £120 - or a USB to TV converter @ about £40.
:wink:
franito
Oh!!
Thanks very much. I tought it could be possible 😞
