Can Sony Vaio notebooks play blue ray?
JamesTopman
I have a SV model: SVS1313C5E, i want to buy a blue ray but not sure how to check if my laptop even supports it.
rich912
Unfortunatey you don't have a drive that supports Blu-ray. If it was capable of reading Blu-ray then BD-ROM would have been checked under read features.
Rich
Go n-éirí an bóthar leat
4 REPLIES 4
rich912
Hi James,
The answer depends on whether you have an optical drive capable of reading Blu-ray discs.
There are various free utilities that will provide information on the capabilities of your drive. The following link provides 5 such tools.
https://www.raymond.cc/blog/do-you-know-your-cd-or-dvd-drive-burning-capabilities/
Rich
JamesTopman
Ok so what capabilities am i looking for? i'm using VSO inspector and this shows up:
How do i know that it can support blue ray from this. I dont know anything about drives.
rich912
Rich
JamesTopman
damn. okay thanks.
