Can't find Vaio Control Center og Support Central
profile.country.da_DK.title
abbetved
I need to disable the Touech Pad and have found out how to do it. It starts with finding Vaio Control Cnter og Vaio Support Channel under "all programs". I can't find neither. Can they have been deleted and if yes, how do I reinstall them?
Hi abbetved,
Pleasee let us know which Vaio model you have and which Operating System you are using (XP, Vista, Windows 7).  Are you using the original OS?
The model type will be shown on the screen surround at the bottom.
:thinking:
abbetved
Dear Blencogo,
My model is VGN.FW31ZJ. Windows 7 Home Premium. And the OS has not been changed.
Seing forward to your answer.
Kind regards
Finn Möbius
abbetved
Have nov found and downloaded the control center but it shows nothing about keyboard and/or mouse. Still can't find support central.
