I really want to upgrade my graphics on the PCV V1/ G but not sure if you can or where to?
This cannot be done due to the non-standard form.
so theirs absolute no way i can do anything to upgrade the graphics ?
Nope
I've just had some advice from e-support about updating the graphics driver - I'm downloading a new one right now and am hoping it may make some kind of improvement - okay it's not the same as a proper upgrade but I figure every little bit helps - hopefully Sony will improve this aspect of the V1 if they bring out future models - it's definitely the weakest aspect of the machine
what driver is it ?
can i have a link to it and did it make a difference?
Just go to e-support - downloadable drivers et al - they update them regularly - truth be told though it has not made a hell of a lot of difference
