Just got a PGN-FE48E off my insurance company as a replacement after a break in. I only had a crappy fujitsu siemens so I thught Id done well except for loosing all my data!! but this new machine has Vista...yeah looks nice.....doesnt run Premiere or Photoshop or Audition or the drivers for me printer so basically I have a machine I can use MS office on and surf the Net and thats about it. Am I missing soemthing here or is Vista this useless?
I was thinking of installing XP but I dont think there ara ny drivers for XP for this machine.
Can anyoen offer any help with this one, I am even considering flogging ti on ebay adn buying an old xp machine......
Are there patches, or does anyone know how to load XP on this model.
I am a man of infinte tolerance but this is really peeing me off
I use vista on both my vaio laptop, and my desktop and both run audition, photoshop fine. Audition runs with desktop compisition disabled but runs perfectly fine.
What version of audition are you using?
what about premiere the lsit in wiki says photoshop and pemeiere whoudl work but they dont they jsut stop loading no error messages audition stops after an error message saying that the colour scheme is wrong.
think I'll flog it on ebay and get an xp model
Photoshop definately works for me, although Idon't use Audition.
Stick with it if you can. Its taken me a while to get to grips with the intricacies of Vista, but now I have I am actually a fan.
Are there no patches on Adobe.com?
When installing them right-click on the installer -> properties
change the compatibility to XP SP2.
The colour scheme should just change for audition and it should continue to work. Its just not compatible with the trasparency because of the way it is written.
