Catalyst control center not working
miceast11
Hi I get this when booting up.
Catalyst Control Centre monitor program is not working
See file.
How can this be fixed.
Mick
profile.country.el_GR.title
pankonto
You have to uninstall it and install it again,at least that's the way I fixed it.
How to Uninstall:
1.Go to Control Panel
2.Go to Programs and Features
3.Find AMD Catalyst Install Manager and click on it
4.Then choose uninstall manager
5.Choose Custom and click the Next button
6.Then select only the Catalyst Control Center and click next
After that install it again and you will be fine(to find the newest version of the Control Center go to http://support.amd.com/us/gpudownload/Pages/index.aspx?src=CCC-CheckForDriverUpdates and choose your graphics model).
Hope this helps ,reply and let me know what happened.
pankonto
How to Uninstall:
nicrose86
I have the same problem. WHen I download the driver for the Radeon HD4500, it gives me the error "graphics adaptor not supported", contact your notebook supplier for a driver update. any ideas?
pankonto
I found out that if you use this update from Sony Support it works perfectly http://support.vaio.sony.eu/computing/vaio/downloads/info/info.aspx?l=en_GB&url=VAIO/Updates/EP00002...
(It may say update for HD 5600 but the drivers recognise automatically your hardware and update it - mine is HD 4570)
Also you can dowload and install the control center regardless of an OEM or a non OEM card.
My  card updates its drivers only from VAIO but the control center can be  updated from the AMD site, I tried it to solve problems with my control  center (It works without any problems, also you can dowload and install  hydravision from there).
Hope this helps.
