Hi, i try to burn CD with music or photo,s. It seems that it works upto 99% and then the systems fails , Anyone knows what to do ?
Which program does this happen in?
Hi , i want to burn a dvd on my vaio zone but just before it is completed burning a pop up appears and says that there was an error while trying to burn the dvd
Hi sjors,
Are you able to try a different burning program..
The model i am using is the VGC-V2M and with witch burning program it coms I do not know, sjors
Try Click2DVD then
Thank you kee-loo!! I own the VAIO 18 months and did not explore the Click to DVD yet . I used picture package sofar. However the same problem exist. If I try to burn a CD or DVD after 99% I get a message "an error has occurred and I tried to convert the files again to MPEG ( because I found this in the help section) but it still gave me the same message. Any suggestions?
regards
sjors
Hi sjors,
There is a firmware update for your drive and an update for Click to DVD HERE - have you downloaded them?
I don't want to worry you but if you have the Sony DW-D56A - it is a problem drive. Have a look AT THIS THREAD
If in dout use NERO 7 god i live and die buy it
