change CPU yes or no
profile.country.de_DE.title
@4566483401003655
Hello i have a new 215m but most of my pc-games working bad
At first i have a grt 815m end oll games running very gut with a resolution 1024 x 768
it´s this a problem from the ATI graphiks or from the cpu.
can i change the cpu to a 745 or 735 centrino.
Games will allways running bad with 800 x 600 and katalysti 5.2 driver verry slow ( Fare Cry / need for speed underground ):smileysad:
seb21__
What is this for a VAIO?
?-?215M
seb21__
If it a PCG-FR215M or a PCG-K215M, then you have a ATI Radeon IGP345M. Which has no own VRAM. This graphics card is to slow for playing games.
If it a VGN-A215M then you a ATI mobility Radeon 9200. Which has 64 MB VRAM. That's enough for playing games. But it's not enough for the newest games.
I wouldn't upgrade the CPU. That wouldn't fix the problem. You would get only overheating problems.
Runs you VAIO with battery power?
kee-lo_
I agree with Seb, the CPU can only do so much, the GPU is now just as important.
