clean my computer
tonypi
clean my computer
My computer is full of stuff, and i would like to erase everything in my computer... format my computer how can i do that??? i have a vaio vgn-fe31h.
thanks
broochie
thanks
Well hello there, seems the stuff is not that important to you, but u juss might want to back up some of that, anyway if you did create your restore discs sweet , but if you did not first you have to create your restore discs, you are gon need them if you're gon wipe out your pc clean to factory state.
If you have the discs, make sure you have disc one of the lot in the drive when you start your pc & when it asks you if you want to boot from the disc, just hit any key, follow the instructions & you should be fine from then on..
Good luck :cool:
Thalamus.
Champion
Hi tonypi,
The vaio Recovery Utility will enable you to restore your Vaio back to the original OS and Pre-installed applications..
Here is a guide should you need it on how to use VAIO Recovery Utility
Make sure you back-up important data first.. :wink:
