Cleaning of keyboard
jescor
Hi again,
I need to take out the keyboard of my Vaio VGN-FS315Z so that I can retire an small plastic foreing mater, which has entered into it and makes that one letter can not be properly pushed.
Anyone can instruct to me how to do it ???
Thanks a lot.
jescor
It seems that after 104 visits to this query .... nobody is able to give a reply ??
Where are the Vaio experts and gurus ???????
I'm sure if anyone can help they will. Unfortunately, if they can't help you will have to accept that and look for your own solution.
Each Vaio has a different key retention mechanism. Have a look at the picture here for your model: -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180465162634&ih=008&category=31534&ssPageName=m...
Even the manual for your model (attached below) only tells you how to remove the entire keyboard.
:slight_frown:
