Cleaning The Screen.
danielclark2
Hello
Can anyone give me some Tips on what to keep my AR21S's Screen clean with !!!!!!.It's a nightmare. :thinking:
Kind Regards.
Danny
24 REPLIES 24
biancavaio
Hey ...well if you go into currys or pcworld they have a product called
IXOS - Anti Static
Screen Cleaning Gel Spray
Its costs £4.99 and it does they job great , but i think the prices of this cleaning product may have gone up , but of course im sure they also have different products for you to choose from
hope that helps
Bianca
Thalamus.
Champion
Hi Danny,
I use nothing more than a dry microfibre cloth to clean my screen and occasionally I might breathe on the screen to remove some spots. These are available from most shops now. :slight_smile:
biancavaio
Thalamus.....the breath or the cloth ...im confused
xxx
Thalamus.
Champion
xxx
I breathe on the the screen and then gently clean any stubborn marks with the microfibre cloth.. :slight_smile:
biancavaio
oo ..soz
xx
Thalamus.
Champion
No problem Bianca, it was my spelling mistake... [:">]
danielclark2
Thanks Bianca
I will give it a go
Ta Danny.
danielclark2
Thanks for the Advice theres nothing wrong with a bit of spit & polish.
Thalamus.
Champion
Absolutely... :smileygrin:
