Click DVD - Space exceeeded
Lonslo
Hi guys
Can anyone help??
I want to use "Click to DVD" to burn a downloaded movie from BitLord onto DVD.
After importing the AVI file I got a message telling me that the estimated DVD used space exceeds the maximum size of the DVD disc.
On checking I found that the saved project file is 9GB. Therefore the problem.
However I know that other DVD authoring software has an option to get the file to fit the space available. Kind of "smart fit" option.
Is this possible with Click to DVD?
Lonslo
drali
I had so many problems with this program when I started using it, it's brilliant but 'buggy'
Try using Vaio Update and update it serially 2-3 times until there are no more updates for the program, it should then work
:wink:
