I'm a clie user for nearly a Year now. I bought mine in the US. Now I came back to France, I would like to know if it's possible to get software and menus on the PDA in French. Thanks for your contribution
Hi Jerome
Sorry I can't give you a direct answer, but you could try posting your question at the ClieSource forum. http://www.cliesource.com/
Good luck.
Alan.
Sorry to inform you that there will be no possibility to change the OS-user-interface into french. The US are monolingual, while with the european versions you have the choice of english, german and french...
David
Yep, and if any change is made inside the ROM files, you will loose warranty. :smileyrolling_eyes: :!:
For having French menus and softs, the only way is to purchase it in Europe.
