Hi there,
I would like to know if it is harmless to have my lid closed while my vgn-sz1 vaio is running. Is there a possibiliy of overheat problems if i do this or while playing music when the lid is closed?
Thanks in advance.
Hi patonios,
I think there would be heat issues if you tried to run your Vaio with the lid closed.
As your vaio's speakers would be then be inside the closed laptop, the sound quality would be very poor unless you intended to connect your vaio to an external set of speakers.
What Thalamus said really, some fans are near the speakers too
Thanks once more for your immediate answers.
So you suggest me even if i have a projector connected and external speakers (so that both my monitor and speakers wont work) to keep my lid open because of possible funs near to the speakers. i'll follow that advice cause i love my vaio .
Thanks again.
p.s How can you answer so quickly you are 24h a day connected??? you are doing great job here.
Hi patonios,
You're welcome,
Yes I think it would be wise to leave your notebook open even when connected to a projector and external speakers..
