The CMOS battery on my laptop is dying since each time i switch off and on again it loses the time/date settings
Searched on internet to no avail so does anyone know where the battery is located for the Vaio FW series laptops?
I would ideally like to replace it myself unless it involves dismantling the whole pc / motherboard
Any assistance is appreciated
Solved! Go to Solution.
I can show you where it is: -
and what it looks like: -
Under the touchpad ........ But you will have to work out how to get to it.
Hi PeShyXP,
It's was not so easy to find, but you will find a good general... How to replace the CMOS battery step-by-step guide here...
