Connect VPCEH1S0E to tv?
Simmy78
What cables do I need to connect VPCEH1S0E to tv? Quite an old tv but has s-video connection.
You will need a signal converter box to change the VGA output signal to S-Video or Composite Video.
You will find several at Amazon from £10 to £150 - here is one of the cheap ones: -
http://www.amazon.co.uk/Composite-Converter-S-Video-Adapter-stereo/dp/B004TCWKVC/ref=sr_1_11?ie=UTF8...
:dizzy:
:dizzy:
Simmy78
Got the converter box thanks, plugged the vga cable from the laptop into the 'in' bit on the converter box and then the s-video cable from the box into the tv. The picture that comes up isn't clear and is flickery, any ideas?
