Connecting my Notebook to TV??
Lacky
Can someone plz help me on how to connect my VGN FS 115-M to a TV, to watch some movies and use it as a DVD-player?? The cable i use with my computer for that doesn't work since the Notebook doesn't have that SHVS Output. So how can i still do that?
Thanks in advance.
Lacky
Nobody??
chris_lewis
Hi, The only option you have is to get a HD15 to Scart or composite video convertor, £50+ you will need to look in computer shops, I havent seen one for a while though,
Amazon have DVD players for £20, I think you have your answer.
Sorry its probably not what you want to hear.
C
mvanwambeke
There is indeed on your laptop not such function included.
The only option you have is to convert the signal coming from the VGA out on your computer to SCART or C-INCH( white, yellow, red plugs).
