How do you connect external speakers to the Vaio V2M
I think you find the answer in the manual.
I have looked at all the manuals and there is no audio line out only line in. I want to connect Sony SRS D313. Can I use the s/pdif port on my vaio v2m
The only way for audio to get out is via the headphone socket.
Thank you Ke-loo working well did try that at first, no sound tried it again and worked perfectly.
No problem
Sorry, Kee-Lo, Thank you again
