Couple of problems :( pleez help :)
bazgrant
Ok,
so all of a sudden when i boot up my vaio i get the windows error message "stub has stopped working" i cant figure out why though.
the other thing is, i noticed that for some reason windows calendar is not installed at all in vista home premium on my vaio, anybody else notice this or know anyway how i can get it installed please?
thanks in advance :slight_smile:
rich912
Hi bazgrant,
I can’t help you with your first question but have a look at this link http://www.winvistaclub.com/t159.html
Have you checked C:\Program Files\Windows Calendar.
If the folder exists then right click the WinCal executable and select either ‘pin to start menu’ or ‘create shortcut’
Double clicking WinCal will also launch the application.
Go n-éirí an bóthar leat
