Back again with another query.
I deleted the restore partition as I thought I had a good set of restore DVDs
I found later when its too late, that disc 2 was empty!
Before deleting it... I made a backup of the restore partition on another drive (USB drive)
Can I create/run the restore DVD process from here?
Not to my knowledge.
You'd be better trying to put that partition back on the hard disk.
