Dead HDD?
andrewparkes
Dead HDD?
Just tried to turn on my laptop, and it wont boot, get the loading part then it just stays black, all 3 lights are on solid on the front, so im assuming that the HD is dead, or even the m/board? Anyone shead any further light on the matter?
4 REPLIES 4
kee-lo_
Does the VAIO logo come on at startup?
andrewparkes
yes but thats about it.
then goes to the scrolling bar bit as if its loading, then thats it
tonybeard
It would tell you that it can't detect the hard drive. No it is more likely failing to boot sequence the usb hub or the modules of RAM has become unseated or both whatever. Try F3 and go into 'advanced' and 'last known good config'. If that doesn't work open up the RAM Module covr underneath the laptop (if your model permits) and re seat the RAM and try again.
andrewparkes
well its getting picked up for repair tomorrow.
Taking almost 10 minutes from pressing power button before can actually use it after a fresh install was taking the pi55, so sony are going to look at it!
