Desktop icons rearrange after projector connected-VGN-NS10L Vista
davshurl
When ever I connect to a projector or use the laptop to feed my TV to view iPlayer the resolution on the laptop automatically changes.  This is no problem real as it reverts when I disconnect.  However, the desktop icons are rearranged when the cable is disconnected and resolution reverts to normal.  Can I stop thiis happening?  It is not a big deal - just very annoying!
Message was edited by: davshurl
DaveBloke
rich912
Hi DaveBloke,
As far as I am ware there are no settings within Windows that will fix or restore icon settings after a change of screen resolution other than a re-boot.
There are however third party programs that claim to do this but as I have not tried any I cannot confirm this.
Have a look at the following link as you may find something there to help.
http://www.wincert.net/forum/index.php?/topic/7332-how-lockpin-desktop-icons-once-they-are-arranged/
You could also try a Google for other third party applications.
Rich
Go n-éirí an bóthar leat
nikkilim
I get this issue from time to time. Try updating your display drivers. Hopefully it would help. https://imagicon.info/cat/12-13/vmware_happy.gif
Thalamus.
Champion
Updating a Vaio's display drivers will not restore icons back to how you had personalised them..
Please be carefull with your advice as it could have a negative affect..:smileywink:
