Disable onboard soundcard
JS_Bach
Hi all!
I have set up my Vaio FS-215S for music production work only with an RME Multiface II soundcard which is connected on a PCMCIA slot.
I am experiencing many problems that I am almost certain that have their roots on the onboard Vaio soundcard. Is there a way I can disable this soundcard so I can be trouble free?
That said, I have already tried to disable it in the device manager but still gets in the way. Is there a way to disable it from the BIOS?Unfortunately I have not found such an option.:smileysad:
The only thing I haven't found so far is to uninstall the drivers of the soundcard since I won't be able to reinstall them.
Any help would be highly appreciated:smileyhappy:
0 REPLIES 0
