HI,
I have just recently replaced HDD with SSD on my SVT1311 laptop and now everytime I boot I am greeted with Press Ctrl I for RAID configuration .
Is there a way to disable this screen as it takes approx ~3 sec on that screen increasing the boot time.
-Rohan
Hi Rohan_b and welcome.
Have you tried pressing Ctrl+I during boot to enter the BIOS RAID configuration and Disable/Delete the RAID configuration?
Hi Blencogo,
Thanks for the reply.
I havent tried that option but if I do delete disable RAID that would actually disable RAID configuration, my concern here is to have RAID configured but not to display the utility screen everytime I boot.
Sorry - I misunderstood. Did your model have a Hybrid HDD/SSD drive? Or does it have room for 2 identical SSDs?
If you now just have a single SSD, I don't think you can run RAID.
It used to have hybrid HDD/SSD drive. I have replaced the HDD with another SSD so it is now SSD/SSD config.
So I assume I should be able to run RAID
As I understand the hybrid drive is a single drive that incorporates both HDD for storage and SSD as cache. So when replaced by an SSD you have one single SSD drive not SSD/SSD.
Rich
