Hi
Can anyone let me know how to disable the sound warnings - "Your battery is fully charged". Can be a little intrusive especially when you're watcing a film etc
Go to Start > Control Panel > Sounds and select none for the ones you don't want to hear
adjust power properties under alarm, u can select or unselect the sound warning option.
Thanks - that's solved it.
As with everything it's easy when you know how - again many thanks.
Clive
