Recently i reinstalled XPhome on my Vaio PCG-FX602. On boot the display randomly darkens to almost no display at all. I can hardly see my mouse move on the screen. When i close the lid, the system goes on standby. When awakening from standby, the display is as normal. But it repeatedly the problems re-appears. It even happens when in BIOS, so its not Windows related...
Could a flash BIOS solve the problem? Or is there another workaround?
(btw: i don't want to run a flash BIOS, because on another vaio it didn't work. Vaio broken, expensive repair...)
If , as you say, it happens when in the Bios, I would agree its not a Windows problem and is hardware related.
It may be as simple as a ribbon cable replacement, but it will need to be diagnosed.
Its not Bios related and as you say Bios upgrades are best avoided.
To let it be diagnosed is also a bit expensive. What about checking it myself? Just to see if the all the cables are connected.
Nice bike btw.
Nice bike btw.
Sounds like that inverter problem a lot of FX users had (wonder what ever happened to Elaine?)
Never knew you knew her Rich - thanks for the info
