DLL not available
Rejith
DLL not available
I got a recent problem while switching On my notebook. A dialog box opens up with the following text :
"The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\WINDOWS\system32\HHCTRL.OCX occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL."
But, the notebook works as earlier (maybe some applications which Im not using at the moment may not work) inspite of this message appearing !!
Require some support on this.
Rejith.
rich912
Hi Rejith and welcome to the forum.
It would seem that a recent Windows update is causing the problem. Have a look at this thread .
Go n-éirí an bóthar leat
