docking station for Sony Vaio SVT1311A4E
decortese
Is possible to use an universal USB docking station (including the power on switch) for the ultrabook SVT1311A4E?
Thanks in advance
Drewde
Administrator
I'm not sure that it is. I'll let you know if i come across anything.
Thanks,
Drew
decortese
Hello all,
looking different PCs, there is an utility (power management) in the BIOS that allows to configure the keyboard for the power on of PC.
In case of Vaio SVT1311A4E if you go to the bios through hold the F2 , You don't have the above possibility. In other word it seems that the bios configuration for the VAIO is very poor. Do You know a way to fowardered the question to Sony Vaio developer?
