Does vpceb1s1e read SDHC-card?
profile.country.fi_FI.title
marpyry
The topic is my question. I cannot find the info anywhere. If the sd slot in my vaio does not read a sdhc card of a camera, is there any way to make it work?
Thank you
rich912
Hi marpyry,
According to pages 57-59 of the manual your model it will read SDHC.
SD memory cards with capacity of up to 2 GB and SDHC memory cards with capacity of up to 32 GB have been tested and found compatible with your computer.”
ftp://ftp.vaio-link.com/pub/manuals/Notebooks/VPCE/VPCE_H_EN.pdf
Rich
Go n-éirí an bóthar leat
rich912
Hi marpyry,
Rich
marpyry
Thank you very much! This was a helpful information!
rich912
You’re welcome marpyry.
