DOWGRADE TO XP WITH A VGN-N21Z | TROUBLE WITH UTILITIES
klems
hey guys,
I've downgrade to Xp with my VGN-N21Z and my laptop is really more faster now!
All my drivers are ok and I'm not trying to install the VAIO power managment but I can't be able to find a setup that works fine.
I've try to install the utility pack from the VGN-N19VP/B but it's the same.
Any help? :tongue:
Klems.
Hi klems,
Most members have had success using the Preinstalled XP Utilities from the VGN-N11S (probably the same as for the N19-Series).
Have you installed ALL the Utilities and installed the first three Utilities in order: -
1. Sony Utilities
2. Sony Shared Library
3. VAIO Event Service
:thinking:
klems
Ok I'll try on this way... I have perhaps made a mistake on the install order.
Will let you know
Thanks!!! :slight_smile:
