DR-GA100 Headset; Mute Button not working
profile.country.de_AT.title
Lordofflies
Hello,
I have bought the GA-100 Headset http://www.sony.lv/product/cpp-headsets/dr-ga100 last week and I am very happy with the sound/mic/wearing quality.
There is only one big problem. The "MUTE" Button on the controls seems not to work. Even when i press it I am not muted (Tested in Skype, Teamspeak). One guy on Amazon does have the same problem with his controls.
I would like to know if this is kind of a defect that is "usual" to all GA100 Headsets, or if there is just a higher possibilty to get a broken one.
Does someone of you has the headset and can tell me about his experiences?
I would also appreciate an answere directly from SONY.
Thank you! :slight_smile:
gugabackhand
This could be a hardware issue. How old is this headset if I may ask? You might want to call tech support and check your options here.  https://imagicon.info/cat/12-13/vmware_happy.gif
Lordofflies
The headset itself is not even 2 weeks old.
I'm just wondering if this issue is appearing on every GA-100 Headset..
