Hallo!
I am looking for a new driver for my all in one.
Intel(R) HM65 Express Chipset Family LPC Interface Controller - 1C49 *SNY5001
Bluetooth-Funkgerät USB\VID_0489&PID_E027
USB\VID_1926&PID_0BCE&MI_00
PCI-Bus 0, Gerät 22, Funktion 0 PCI\VEN_8086&DEV_1C3A&SUBSYS_908E104D
Hi apfelek.
I presume you mean VPCL22Z1E?
You will find all the available drivers for your model here:-
http://www.sony.co.uk/support/en/product/VPCL22Z1E
You don't say which OS you are using. The 'SNY5001' is called "SFEP Driver" in the downloads list and is only in the Windows 7 list here:-
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/SODFEP_00224384_0042_5696/VPCL22Z1E
Hello,
Thank you so much for previous tips.
That helped a lot in solving the issue. Now, I have encountered another problem. While formatting with Acronis Treu Image, my MBR on boot partition was removed so I am not able to access recovery partition.
Could you please make an MBR copy from original Windows from Sony for me? Just a small file made with Bootice or MBRBackup.
Also, would you know which application is responsible for the keyboard function button as I am not able to brighten or darken my screen?
I appreciate you help.
