DRIVER NEEDED: Analog Devices AD1981B (Windows XP)
davidmorris87
Hi.
I'm looking for a driver for this:
Audio Chipset: AD1981B - 16-bit CD-quality stereo sound
Chipset Manufacturer: Analog Devices
Audio Type: AC Link
Computer model is Sony Vaio PCV-RS402 running Windows XP.
Thanks in advance to anyone able to help me.
rich912
Hi davidmorris87,
Have a look in Device Manager for the audio device that possibly has a yellow warning symbol indicating that the correct drivers are not installed or possibly the audio device is listed as something other than AD1981B. If so try updating the driver using the ‘Have Disk’ method.
Extract the files from the installation package to a known location.
Click Start > Control Panel.
Double click Device Manager.
Right click the device and select Properties
Click the Driver tab.
Click Update Driver.
Click Browse my computer for driver software.
Click Let me pick from a list...
Click Have Disk....
Click Browse and navigate to the folder where you placed the extracted files.
Click OK.
Click Next.
Click Finish.
Reboot your system if requested.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
gugabackhand
Hi. Try searching for the driver here. http://www.sony.co.uk/support/en/product/PCV-RS402/updates Good luck. https://imagicon.info/cat/12-13/vmware_happy.gif
davidmorris87
No joy I'm afraid. And when I try installing the initial drivers I get no success either.
I should adivse that I recently had to reinstall XP from a disc due to numerous issues.
Upon successfully doing so, the only thing I am now without is sound. I've tried numerous things but I just cannot get my sound working.
When I click to run the exe file from the driver (all drivers were on my D drive so remain in their initial state), nothing happens. No error message, nothing.
Really stuck here. Any further assistance would be most appreciated.
rich912
Hi davidmorris87,
Click Have Disk....
Click OK.
Click Next.
Click Finish.
Rich
davidmorris87
You my friend, are an absolute star!! It was layed out slightly differently from the steps listed above but I kept to the steps as much as possible and improvised where necessary. Mission accomplished. Enjoy the rest of your weekend! :smileyhappy::smileyhappy::smileyhappy:
Message was edited by: davidmorris87
rich912
My mistake, I gave you the Have Disk method for Vista/Win7 not XP, but pleased to hear that you figured it out...
For anyone else following this thread here is the correct procedure for XP.
  1. Extract the files from the installation package.
  2. Click Start > Control Panel.
  3. Double-click the System icon. Note: Select Switch to classic view if the system icon is not visible.
  4. Click the Hardware tab.
  5. Click Device Manager.
  6. Click the + symbol in front Device Category to expand the section.
  7. Right-click the Device and click Properties.
  8. Click the Driver tab.
  9. Click Update Driver.
  10. Click No, not this time and click Next.
  11. Click Install from a list or specified location and click Next.
  12. Click Don't search. I will choose the driver to install and click Next.
  13. Click Have Disk....
  14. Click Browse and navigate to the folder where you placed the extracted files.
  15. Click OK.
  16. Click Next.
  17. Click Finish.
  18. Reboot your system if requested.
Rich
Message was edited by: rich912
Edited to provide correct procedure for XP
