Drivers for VAIO pcg-71911M product name VPCEH3N6E
VaioPCG71911M
Hello, ALL!
Need a HELP! My sister KILLED my beloved laptop and now i have to install ALL DRIVERS again. I ask you to help me with it
My laptop is Vaio
Model pcg-71911M
I need all drivers for Windows 7 32-bit Operating System
Thank you in advance!
Kind regards,
Dennis
Hi PCG71911M and welcome.
Everything on the Sony website only uses the Vaio Model VPCEH3N6E folllowed by /W for white models and /B for black models.  You will find nothing using the PCG number.
This model was released with Windows 7 HP 64-bit and so most drivers are 64-bit only.
Did you try recovering your Vaio back to factory settings by pressing the ASSIST button when the Vaio is turned off fully?  Is there a particular reason why you want 32-bit?
To see all the available drivers: -
Click on Support (at the top of this screen)
Click on Online Support
Type your Vaio Model into the 'Get Started' box (VPCEH3N6E/B or VPCEH3N6E/W)
Select the 'Downloads' Tab and you will find the Windows 7 Drivers under both the Preinstalled Drivers and the Latest Downloads Tabs.
http://www.sony.co.uk/support/en/product/VPCEH3N6E_B/updates
Not all preinstalled software can be downloaded.
:thinking:
9 REPLIES 9
:thinking:
VaioPCG71911M
All Preinstalled Drivers and the Latest Downloads Tabs for 64-bit only. So i will try later now im re-installing my 32 for 64.
10X for HELP!
I CANNOT FOUND BLUTOOTH  DEVICE
i need new drivers in pcg-71911m
rich912
Hi basilisap1297,
As per the above you need to search the support site using the Product Name, not the model number. It may be a VPCEH3N6E but you need to check this reference on the sticker on the underside of the notebook, in Vaio Control Center > System Information or the BIOS.
Rich
Go n-éirí an bóthar leat
masblee
I still search
rich912
Hi masblee,
Where are you searching, what are you searching for and for which Vaio product?
Rich
driver de red
