Drives for XP
mscala
Drives for XP
Hi.
i have buy VGN-C2Z/B vaio.
Where can i find the drivers of Windows XP?
Thanx
4 REPLIES 4
Hi mscala and welcome.
There are no XP Drivers for your model and Sony will only support Vista on your Vaio.
Make sure you create at least two sets of recovery discs because you will have to reinstall Vista if you have a warranty claim or need a repair.
The closest set of XP Drivers are those for the Vaio VGN-C1Z but you will need to keep your VCC4 Camera Driver because this is different on the C1 series.
:slight_frown:
mscala
but for my work is necessary to operate with windows xp.
How can i do?
Costasp has done this with his AR31M Vaio.
Have a good look at THIS RECENT THREAD
The procedure is going to be very similar for you but you will use the C1Z drivers and utilities from Sony Support Downloads C1Z
:wink:
mscala
thanx very much!
