duo 11 touch scrren
dotraphael
duo 11 touch scrren
Hi All,
from time to time, my duo 11 touch screen stops working. i need to reboot/shutdown the computer couple of times to have it working again..
is there a way to enable/disable the touch screen so i dont need to reboot the laptop?
thanks
stavrosd2006
i own a duo 11 since 1st may and i want to know what happened.
did you drop it,misused it, or suddenly touch screen stoped working.
did you update all your drivers via vaio care?
there were a lot of updates since first use till now.
as far as i messed with settings i could not find one for disabling touch.
Message was edited by: stavrosd2006
