Duplication of photos in picture folder
platypus61
On several occasions my Vaio Computer has created a folder with two images in it for each picture file in the folders in my picture library.
This happened a few months ago, and more recently keeps happening every day. When I find the duplicated folders within each folder, I delete them - but this then clogs up my recycle bin and last time took an hour to delete. I have scanned the computer for any viruses, but nothing was found. The photos are duplicated at such a rate I can not keep on top of deleting them. To try and solve this, I removed the entire photo collection, and re-installed the photos, but this has not helped.
Can anyone give any advice as it is getting to the stage where I can no longer keep photos in my pictures folder.
tweety2b
Ex Commander (Was always on)
Have you been using Picture Motion Browser or Media Go recently?
If so you better check your settings for those applications as they both have some kind of pictures function and they both might be running in the background doing the same thing.
Kindest regards,
Nico
Nico Henderijckx
(ex-Sony employee - fanboy forever)
