DVD/CD Eject Button Stopped Working on VAIO VGN-A297XP.Notebook
JohnHam
Hello,
I've just bought a Sony VAIO VGN-A297XP Notebook.
It worked perfectly for a couple of days, then the "Eject" buton stopped working. I can still eject using the options from software and by pressing the "reset" button, but not the CD Eject button. Also nothing comes on the screen when the button is pressed as before. Help!!!
kee-lo_
Hi
If you reinstall the UTILS.EXE from C:\Drivers your eject key should work again.
