DVD-RW upgrade for RX202
wargrave
Is it possible to fit a DVD-RW in place of my DVD-RAM drive and still retain the super sony design. If so how would I go about it and what drive should I buy and where from.
VAIOneer
You should be able to fit a DVD-RW no problems in replacement of your DVD.
There a loads of shop out there that supply such things. You just need to find one that is a close macth to your VAIO colours... remember, most standard PC peripherals come in the usual beige and beige associated colours.
As for which one.. thats down to persoanl preference and finance available.
:cool:
