EFI after BIOS Update
Wiesel1234
Hi, i installed first the "hardware virtualization" bios update and some days later the bios update for windows 7 on my z41. Since these updates, i'm not able to run the EFI manager (pressing ESC on startup). If i try to do this, my vaio will instantly reboot at the time, EFI should load it's manager. Does anyone also have this problem?
0 REPLIES 0
