enable color in arcsoft webcam
skonagalla
the webcam is black and white in my all new i7 laptop (SVE1511C5E)
i see the colorenable is disabled in arcsoft webcam settings but it can't be enabled
reinstalled the driver but it did not help
can someone let me know on how to enable color in webcam
firionicable
Do you think there is a defective problem on your webcam? Try to set it on default and use like 2-3 software for your webcam. If the color won't change, I suggest for you to have it checked and replaced.
